Home > Technical (L322) > TDV8 engine chirp
Martin
Site Admin
TDV8 engine chirp
What's this chirp?
Sounds slightly after putting your foot on the pedal, given the delay, turbo or EGR related?
Post #276942 21st Aug 2014 5:38pm
Googsy
Sounds like a belt to me. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #276946 21st Aug 2014 7:05pm
belt or something rattling on the air intake side... ... - .- -.
Post #276950 21st Aug 2014 7:12pm
Fan belt, tensioner? Alternator bearings? I wouldn't think turbo or EGR straight away...
Post #276952 21st Aug 2014 7:27pm
Martin
Site Admin
It's just had new aux belt, pulleys, tensioners and alternator Confused
Reason I thought something engine based is the delay between applying the pedal and the chirp.
Post #276953 21st Aug 2014 7:38pm
Was the noise present before the latest works Martin?
Post #276959 21st Aug 2014 8:05pm
Mikey
Warped exhaust manifold and/or broken stud in the head Big Cry
You may be "lucky", and it's only the turbo-manifold gasket leaking
Generally, it's the rearmost stud on the manifold, but you need to remove or manipulate the heatshield to see it
Post #276961 21st Aug 2014 8:12pm
Martin
Site Admin
There was a horrendous bearing noise from alternator/pulleys, the alternator eventually failed so the whole lot was changed.
Post #277063 22nd Aug 2014 11:00am
I think there is a fault with one of the new components Martin! Can someone drop the alternator belt off just to check the noise stops when run without those components working?
Post #277070 22nd Aug 2014 11:23am
Mikey
Whistle
Post #277170 22nd Aug 2014 9:36pm
Martin, did you get to the bottom of this issue my friend?
Post #278145 30th Aug 2014 10:39am
Martin
Site Admin
Not yet Confused Will update when I've had a chance to get a look at the RR again.
Post #278148 30th Aug 2014 10:48am
Post #278151 30th Aug 2014 10:50am
n1cktdv8
I have a dull whistle when under load, towing mainly but if I go heavy right foot too. sounds like it's coming from nearside of engine bay....any ideas ? Is this where I put the car details and a bit about myself ?........
Post #278181 30th Aug 2014 2:08pm
