Home > Maintenance & Mods (L322) > OEM Floor mat - stupid question |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I doubt it.why not put a bit of filler in shape it and hand paint silver. Present :2008 TDV8 HSE
27th Aug 2014 6:27pm |
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 102 |
I was thinking of putting a bolt through with the head rounded off - just looking for something easy. |
27th Aug 2014 7:18pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3691 |
Pop rivet and a washer on the back is what I did with mine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
27th Aug 2014 9:20pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Dan @ Duckworths sourced me one for a couple of pounds. |
27th Aug 2014 10:06pm |
His resourcefulness knows no bounds!
28th Aug 2014 3:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
stick a bit of solder in the head groove and bob's your uncle,sorted. ... - .- -.
28th Aug 2014 3:38pm |
Dan says 'no' so I think I'll stick with plan A. As above, if I fill the slot it will hardly notice.
28th Aug 2014 4:01pm |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 |
why not just get small coach bolt, wont have a slot in it |
28th Aug 2014 4:05pm |
The coach bolts I can see have heads that are a bit too flat. |
28th Aug 2014 4:32pm |
You can get small stainless dome head set screws from screwfix, some have a hex head in them. Might look better..... There is nothing that can't be fixed with a hammer😜😜
28th Aug 2014 5:36pm |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 |
Everyones favourite
28th Aug 2014 5:49pm |
30th Aug 2014 2:05pm |
perfect Present :2008 TDV8 HSE
30th Aug 2014 3:02pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
i guess its a tribute to how good these csrs actually are as we fret over such a small problem.
30th Aug 2014 5:25pm |
