Home > Wheels & Tyres > steering wheel wobble
retro man 1973
England 2003 Range Rover Vogue Td6 Baltic Blue
Hi all I've brought a 2003 range rover and has a puncture do i need to replace all 4 tyres if can't be fixed please help, it's git original 18inch spare on at min is this ok
Post #277919 28th Aug 2014 7:31pm
Shouldn't need to replace all four. Even if the spare is a different rim size, if it is fitted with the correct tyre (and the others) the overall wheel/tyre circumference will be the same.
Have you got steering wheel wobble as well as a puncture?
Wheel balancing?
Steering/Suspension joints?
Rack? .
Post #277921 28th Aug 2014 7:46pm
retro man 1973
Yes I drove up motorway and all of sudden the steering wheel wobbled like crazy and banging noise from front wheels
Post #277924 28th Aug 2014 8:05pm
Rosco
Sounds worse than it probably is, suspension arms most likely, maybe puncture caused wobble, looks like you have 20" rims, tyres not too expensive for them (relatively) There are some well priced used ones on sale here at the moment which will be good, let us know what info you need as we have all been through everything Thumbs Up Thumbs Up
Post #277926 28th Aug 2014 8:18pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Last week I had a puncture on the rear of my 03 TD6.
I sliver of metal had sliced through the tread, so the tyre could not be repaired.
I only replaced that tyre as all the others had plenty of tread left on them.
I did however have all the wheels rebalanced whilst I was at it and the tracking checked and adjusted all round. Made a hell of a difference to the ride.
I have 20" stormer type wheels fitted, when I went to fit the 18" original I found that the wheel nuts did not fit. I don't know who the F Censored ing idiot was who thought it would be ok to junk the original nuts whilst still having an original wheel in the boot, but if I could have got my hands on him/her at that moment Evil or Very Mad
Anyway, if you have plenty of tread on the good tyres, don't waste your cash on all new.
Post #277940 28th Aug 2014 9:59pm
@ retro
If everything was OK before the puncture.......
Sounds like the spare is not on the hub correctly ? As above could be the nuts....? (But I have those 20" wheels and the 18" spare and similar 18" set I have, works fine with the nuts I have) .
Post #277942 28th Aug 2014 10:28pm
retro man 1973
Thanks all, checked the suspension arms and was the lower arm, and balljiont on other side, replaced and all working, thankyou so much
Post #297076 4th Dec 2014 10:07pm
