Home > In Car Electronics (L322) > Blank Screen
Kiwi_V8
New Zealand 2004 Range Rover Vogue 4.4 V8 Java Black
Yes it is! At least I know that both my nav units are working, although I must admit I'm starting to wish I hadn't started this!
So, I cleaned out the satnav blue connector, hooked it all back up again and I'm back to the blank screen.
Does this mean I've got a dodgy connector, or has the tv unit died?
Any idea how to check whats going on?
Post #279253 5th Sep 2014 4:00pm
mjdronfield
You could PM Baris on here who seems to spend a lot of time with the units in pieces. He will be best to help you fault find from here.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #279255 5th Sep 2014 4:03pm
mjdronfield
Or a dodgy connection between the TV and nav ?
Though not remembering the loom exactly, is that possible ?
That said, the nav would still display wouldn't it ?
I know the units daisy chain....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279256 5th Sep 2014 4:06pm
You've probably got a dodgy connection in the blue plug, possibly due to past water "issues".
I found the only way to clean each of plug sleeved connectors was to use a thick needle with the end broken off.
I held it in a pair of pliers and used it as a scraper, sliding it backwards and forwards in each of the connectors.
Must have worked, never had any trouble since.
Post #279257 5th Sep 2014 4:09pm
Kiwi_V8
Thanks for the tips guys, I think its most likely the connector on the satnav, as it was fine up until the point it was disconnected. Would be a massive coincidence if the tv failed at the same time..
I'll give the needle technique a go and report back on how I get on.
Post #279265 5th Sep 2014 4:19pm
Kiwi_V8
Thought I would finish this up in case anyone else is having the same issue.
For me it turned out to be the TV module. Couldn't see it when it was still in place but one of the pins in the bule connector was missing. I guess messing around in the back when I was pulling the nav unit out might have been just enough to disturb it.
Anyway, found a second hand BMW analogue unit on ebay for £34, fitted it, and all is good once more. Now looking for an aftermarket freeview/reverse camera upgrade to go with it.
Post #282969 26th Sep 2014 4:10pm
