Home > In Car Electronics (L322) > RSE IR Remote Volume not working (headphones no sound)
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
So gang
I need some advice on what to do.
1) I have a 2008 RR with RSE and when I turn on the RSE and the headphones - no sound on the headphones.
2) I have held the headphones really close to the IR in the ceiling but no dice
3) I opened the center ceiling up and took a picture of the the RSE IR blaster with a FLIR camera - the theory being it should be "red" as the IR blasters are on. See attached - it seems like its dead
this leads to the following conclusion that either
A) the IR blaster is bad - SEE FIRST PICTURE - OUTLINE OF FINGER POINTING TO IR BLASTER
or
B) the cable connection going back???? is not connected correctly
C) There is a THIRD cable in there not connected to anything (alarm?????) THIS IS THE SECOND PICTURE
Any suggestions are appreciated.
I want to add one more comment which I am not sure about
WHEN I PLUG IN A IPOD INTO AUX 1 or AUX 2 - there is no sound on the SPEAKERS. (the video is displayed on the RSE screens in the back) - even when I select AUX on the main head unit as an input.
Is this correct behavior? I always thought that connecting a device to the AUX1 or 2 Audio jacks would allow sound to be played on the car speakers (not headphones)
HELP
Alex 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #280758 13th Sep 2014 6:03pm
Nilrem
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Just a tip but there's No need to use a FLIR camera.
If you point an IR device that's transmitting, at say the camera on your mobile phone ,you'll see the IR emitter flashing in the camera view finder.
Post #280764 13th Sep 2014 7:07pm
