![]() | Home > Maintenance & Mods (L322) > Knocking. Front Drop Link Replace & Freeing Seized Nuts |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Its probably an interference thing, it was easier to shim the link than remake the strut bracket. That is the only reason that I can think of, and they aren't going to advertise that. Yesterday I couldn't spell Engineer... Today I are one!
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Hex impact sockets, Ingersoll Rand 2135QTIMAX impact wrench and Hydrovane compressor, job jobbed and never been stuck yet |
I use a De Walt 18v impact wrench, it will work in the middle of a field!! Yesterday I couldn't spell Engineer... Today I are one!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
I can't afford one, I use a FBH.... Pete
Agree miggit & Steptoe.
There are a few advantages to using the 6 sided (hex) sockets, the main one is that they grip the nut / blot across the entire face, and as such reduce the chance of slipping and rounding off the the nut / bolt. They also increase the force applied to the stubborn nut / bolt. If you have a well rusted nut and the edges have been eaten by the tin worm you can still get some purchase on the blighter!
+1 for above.... and if all else fails get some of these
Miggit & Haylands,
PLEASE PLEASE PLEASE DONT TRY THIS ON A FF... The lockers have an outer layer that spins (to stop thieves doing this) and then you will need to have them specialist drilled out which when they damage your Hub, Wheel, etc could turn into ££££'s... |
Craig, I did say 'different type of wheel nut' there is no way they'd work on an internal splined nut. And I know that some wheel nuts have a collar that spins to stop a socket being hammered on, BUT if you have lost the key, you will need to replace the wheel nuts. And so with the aid of a small cold chisel or trusty bent screw driver, you can remove the collar, and then remove the useless wheel nut. Thus doing away with a trip to the stealer's, who will do the same thing and charge you a fortune.
Hay, I was just making it crystal clear to members sir... |
No problems here Bud, unless you've lost your wheel nut key |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
One method I use with success on seized fixings is to actually tighten the nut/bolt/screw a fraction to just break the "seal"
Bashing it with the hammer of Thor works for me |
