Home > Technical (L322) > Where's the Transferbox ECU?
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
In an attempt to solve my transmission problems, I'm replacing the automatic transmission ECU and thought about the transferbox one. However, I can't find the Censored
Where is it??? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #284482 5th Oct 2014 6:08pm
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Its in the sump of the gearbox Im afraid.
Post #284501 5th Oct 2014 7:39pm
Not that one Glynn ??? (whichever one that is???)
The Transfer Box ECU is behind the battery
See here:
http://www.fullfatrr.com/gallery/thumbnails.php?album=331 .
Post #284532 5th Oct 2014 8:49pm
tymh
Thank Censored for that!
Glynn, you had me worried there!
Thanks Joe - I know where the next job is going to be if the transmission ECU doesn't solve it. Tym
Post #284536 5th Oct 2014 9:23pm
On the TD6 the starter inhibitor switch is in the sump, on top of the gearbox on the V8 (below the air intake plenum chamber).
Actually worth checking this is OK too .
Post #284556 5th Oct 2014 10:51pm
tymh
I'll add it to the list!
I don't have a problem starting it, except when it thinks the battery is low, but it isn't ...
Very occasionally I'll try to start it and it feels like a flat battery - not enough juice to turn the starter. I turn off, wait, turn back on and it starts... Tym
Post #284557 5th Oct 2014 10:55pm
