![]() | Home > Maintenance & Mods (L322) > l322 Front indicator Side Light Assembly Mount |
We can supply you the rear of a light with the mounting bracket intact for £75 + P&P... if of interest sir |
Rextter Member Since: 07 Oct 2014 Location: Durham Posts: 10 ![]() ![]() ![]() |
Thank you very much for that Cam-Tech-Craig I will keep that in mind. Now I've had another look at the bracket I see it attaches to the headlight surround so quite a large job. I'll try to repair it with some epoxy resin first and see if that works. When I've taken off the large white plastic nut that holds the side light/indicator on I find they have glued it on the inside - ruining the thread. |
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 ![]() ![]() ![]() |
Hi Rextter, I had the same problem on mine. I bought a whole new LR assembly off the bay for £60 My Motto: If you are going to have one, have a BIG one! |
I did a few "bodgit repairs" on mine, have a look:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
That's not a bodge Joe, that's "alternative engineering" |
