![]() | Home > Maintenance & Mods (L322) > And now for something completel different |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
Can I ask which spec, model and year this is please? I'm guessing from your name it's a 2008?
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Just a guess, but 2008 Range Rover HSE 4.4 V8 Java Black. That's the NA Jag petrol engine with the 6sp zf box. |
Thanks for the speedy guess. I'm asking as I want to confirm this is unlikely to be a TDV8's problem as it has similar symptoms? Rehab is for quitters!!!
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
^ you do know that if you hover the mouse or click on the picture of the car under your name that it tells you the spec etc of the cars? Previously..
I think they all have the same diff, but I might be wrong. |
Thanks Contraband I didn't know that. However on mine it shows only my current TDV8 and not my 4.2 S/C. Can you have more than one? Nothing shows under yours??? Rehab is for quitters!!!
KurtVerbose I was told the TDV8 didn't have this. I'm at my wits end with it so would be delighted it it was correct. Rehab is for quitters!!!
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Yes, the guesses are right. I have a USA spec 2008 FFRR. The exact spec is an HSE LUX. It has the 4.4 nonSC Jaguar V8 and 6 speed transmission. The model specs are different over here, so I don't know the exact UK spec equivalent. AKAIK the car has absolutely everything a Supercharged would have (locking diff, cooled seats, leather, GPS, very nice audio) but no rear seat entertainment system.
Thanks for the confirmation. Rehab is for quitters!!!
Ok mine appears to have the diff lock. Any suggestions how to test this other than replace it?
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
In case you are researching the matter, the rear diff lock is called the Electronic Torque Managed (ETM) Locking Differential.
If you look on your 4x4 info screen whilst turning your terrain response knob, you will see the icon over the rear diff change from a closed green padlock to an open one... That way you will know if your FF came with an EMT |
Thanks Paul. The question is how to test it? I don't think IID can interrogate it. Can it be checked with a meter? Rehab is for quitters!!!
Cam-Tech-Craig there are two open padlocks on the 4X4 screen, one on the rear diff and the other on the transfer box. I thought they only locked automatically when required. Am I wrong?
