Home > In Car Electronics (L322) > Bluetooth connects but no vol
tymtym
United Kingdom 2005 Range Rover Autobiography Black Td6 Java Black
Hi can i firstly say what a cracking forum..
Heres hoping someone can point me in the right direction with my bluetooth problem
car is ffrr vogue with updated bluetooth module so it displays phone book etc when connected to i phone 5
connects ok but if i call my answer phone it mutes radio but then i get no volume from phone etc also if i answer a call i get no audio ??????????
Post #285065 8th Oct 2014 3:37pm
press the left tone button on the nav unit for about 3/4 seconds and it will bring up a 'volume' screen where you can adjust the relevant defults there..
Post #285067 8th Oct 2014 3:58pm
tymtym
Hidden volume
Hi thanks for reply Stan tried that m8 so turned it nearly all way up still nothing
Post #285078 8th Oct 2014 4:28pm
Jez/revere
United Kingdom 2006 Range Rover Vogue TDV8 Barolo Black
Hi there,I'm new to this too....
Just got a 56 rr vogue tdv8 and I've got the same problem. I can connect my phone and call but there is no volume,turned the volume up on screen but still nothing!
Many thanks....
Jez
Post #349067 23rd Sep 2015 11:52am
proser
Is the other person able to hear you when you make a call ??
If not then it may be a problem with the bluetooth module and water ingress Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #349068 23rd Sep 2015 12:01pm
Weegie
Re: Hidden volume
It might be worth re-flashing the bluetooth module.
You would need to have a dealer to do that unless you purchase the GAP iiD tool which is an invaluable piece of kit to have for all sorts of functions. The BT version, although more expensive, is the most versatile. John
GAP iiD BT-Sold
Post #349070 23rd Sep 2015 12:21pm
cropps
England 2002 Range Rover Vogue 4.4 V8 Java Black
Hi
I had the same problem when retro-fitting my blue tooth, everything worked & connected but no volume, it turned out the car had, had a phone kit fitted prieviously, the remants of which were still connected but tucked behind the centre console. When all this was removed & the wire correctly re-instated(speakers) everything worked fine. Lost some skin off my knuckles but OK to do, hope this helps.
Neil
Post #349071 23rd Sep 2015 12:34pm
Jez/revere
Yeah that's right,connects but nothing can be heard both ends!
I guess I can find that in the boot n/s?
Thanks
Post #349079 23rd Sep 2015 1:09pm
proser
unit is left side at the very top - NOKIA stamped on it. Regards
Mark
2012 Westminster
Post #349086 23rd Sep 2015 1:42pm
cropps
Mine was an after market unit fitted behind centre console & tapping into speaker system wiring at that point.
Post #349173 23rd Sep 2015 10:28pm
proser
another question : when you dial a number can you hear the ring tone through the stereo ??
If the answer is no, then your nokia module is goosed Big Cry
I talk from experience and had to replace it - all is well again Very Happy Regards
Mark
2012 Westminster
Post #349387 25th Sep 2015 3:31pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
I'm having the same problem on mine (05 Vogue with the Jag head unit) - phone connects fine, dials on the screen but there is no dialling tone or voices through the stereo even with the volume properly adjusted. If I pick up the phone from the cubbyhole (whilst stationary I hasten to add) and change the sound output from "bluetooth speaker" to "handset", I can talk through it normally - so the problem obviously lies with the car not the connection.
Is there a way to tell by visual inspection if the nokia unit is goosed? NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #353008 19th Oct 2015 9:34am
proser
You will need to remove the unit to check it properly.
check the condition of the pins where the multi connector goes in - serious signs of green corrosion is a indicator of water ingress.
Mine wasn't that bad but had water coming out of the unit when I tipped it up. undid the case and there was signs of water damage on the board. I'll try and get a pic up of the board. Regards
Mark
2012 Westminster
Post #353022 19th Oct 2015 10:31am
Only real way to be sure is to swap it with another unit.
Personally at that juncture its bet to just get the new unit as its a much better setup than even the upgraded nokia units. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #353029 19th Oct 2015 11:03am
mat777
What is the upgraded phone unit? And is it plug and play with the rest of the 05 system? NW060
Post #353034 19th Oct 2015 11:27am
