![]() | Home > Maintenance & Mods (L322) > "Suspension Will Not Lower" - How to fix bulletin |
Just trying to get to grips with my newly acquired IID tool and one of the faults showing up was this:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i think at that time there must have been a 'glitch' or you tried to lower/higher with the door open maybe.. ... - .- -.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
pld118.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I've just had this problem with the car not lowering correctly, Sal too has the same issue. The exhaust muffler (as per tsb) on mine was choked. Cleaned and replaced, so far the problem has not re-occurred. The code is CLA13-64 http://www.fullfatrr.com/forum/topic22136.html Ian |
Hadn't seen that post T24RES and so whilst walking through my IID fault record, like you, I arrived at the same TSB and thought I'd amend my post title with key search words that would probably be easily picked up by future forum searches for the fault.
