![]() | Home > In Car Electronics (L322) > Touch Screen issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35794 ![]() ![]() |
whats your battery like rory?.....and is there any moisture in the rear cubby hole. ... - .- -.
RoryM Member Since: 03 Mar 2013 Location: Ireland Posts: 51 ![]() ![]() ![]() |
Hi Stan, battery is fine and entire boot and cubby holes are completely dry. |
did you check all the connections ... ... - .- -.
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
Whats the image like when you change source ie. TV, reversing camera Sat nav etc? The image looks like it is garbled data which means the LCD is may be working but what is sending it the data is broken or being corrupted.
Its the same in all screens. the touch functions work, Ie, it will change radio station but you just cant see it. I disconnected the fibre optic cables too and that only cut out the radio but not the fuzzy screen. |
does the pattern on the screen change with time or with switching source or is it fixed all the time? |
its the same all the time. its not frozen if you know what I mean. it flutters a bit for what of a better word. |
Looks like you need to replace the head unit or LCD. You might be able to get it repaired, there is a place in USA who might do them but you probably want somewhere more local. If you have no luck with it you can send it to me to look at but not having seen the inside of one I would be wokring blind. |
hmmmm. its happened about 5 or 6 times now. think I'll just get rid of the feckin thing. tis driving me mental. |
if it is intermittent then it could be heat related. |
