![]() | Home > Technical (L322) > rear drivers side door issue |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8805 ![]() ![]() ![]() |
Does the window work from the drivers door and does the puddle light come on?? Pete
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Drivers door works, yes puddle light comes on and the fuse is ok.
Stripped it down today, there is a remote bcm in the door, I swapped passenger to driver side and hey presto it worked, so I now know what to change, lucky escape me thinks,
Try Dan at Duckworths or other site sponsor such as Advanced factors might be cheaper |
Will do |
I've found a second hand unit for 20 quid. Same part number and physically the same but some of the codes are different? Can I kill the car if it's wrong? We're there different types made with the same part number?
Purchased a new rear door controller from lr. 60 quid. Fitted and all is fine. Nice easy fix.
