I’ve currently got a an issue with my drvier’s side front wheel – the first 3cm of the tyre is badly scrubbed on the outside, rest is fine
This is almost certainly because the tracking being out, but there is also a slight vibration when going round shallow corners on the motorway, so possibly a contribution from worn suspension components.
Having replace the front passenger side lower are approx. 2 years ago due to knocking and a similar slight wobble, I’m thinking it’s time to do the driver’s side as well.
I believe in preventative maintenance and putting the car in the garage, even for a day, is a hassle, hence I am thinking of doing a full suspension refresh in one go.
The car has done 101k miles and I’ve previously been advised the rear upper and lower bushes are worn, so I’m thinking:
Front – upper and lower arms, ARB drop links
Rear – upper and lower arms, shock absorbers (these feel worn so thought I may as well replace)
After that, I’ll get my four new Scorpion Zero’s fitted (currently in the cellar three weeks after purchase) and a proper 4 wheel laser alignment.
I’m no expert, so will have missed obvious bits which should also be changed - suggestions please on what other components would you change!
Thanks 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
