Home > Maintenance & Mods (L322) > Making it more secure |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Hidden immobilizer switch or...
24th Oct 2014 6:35pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
Not going to go into it in depth on here but it doesn't matter what you put on it, they will take it if they want it, they can beat anything you can add, in fact they don't have to beat it because the method they use will bypass anything you add to it...
24th Oct 2014 6:42pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
The FFRR can even prevent the valid owner from starting it (especially thinking about the Steering Interlock ECU going faulty, and a host of other things)
24th Oct 2014 7:00pm |
It's OK after complaints from car thieves Land Rover removed the steering lock on the later ones so it's much easier for them now.... Pete
24th Oct 2014 7:10pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Tracker idea sounds good.
24th Oct 2014 10:32pm |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 |
Cheers for the replies. Like the dog option like you say if they want it I suppose it would go. Tracker seems an idea if they ain't got anything to block the signal. If they get it started the tracker will believe its owner will have started it but if they lift it the tracker will alert the tracking centre that it's moving without the engine running.
24th Oct 2014 11:37pm |
Pop up posts for the driveway and tracker would be my thoughts.
25th Oct 2014 7:53am |
