Home > Off Topic > How Hard is it
How Hard is it
Laughing Not what you are thinking ......
Have been trying a few car accessory shops up my neck of the woods to get a 18mm deep 3/8 socket neither of the shops have them including Halfords as for some reason an 18mm deep socket is not standard ... 17mm and 19mm galore but no 18's
Tried Amazon and Fleabay , but thats a 3-5 working day delivery , tried a couple of motor factors ... the same ...
Ah well looks like 3-5 days it is then .... Rolling Eyes Rolling Eyes Rolling Eyes
Post #289182 27th Oct 2014 2:37pm
mzplcg
Mick, I'm with you. I'm finally getting my 18mm spanner into the non-shiny condition that my 17mm and 19mm ones are in with all the 18mm nuts & bolts on this crappy Skoda of mine.
Even the brake calipers on Wifey's XF seem to require a 9mm Allen key. Not the 7mm, 8mm or 10mm that come in every set ever made, no a 9mm one which nobody sells, not even the Snap-On van. Censored
Post #289185 27th Oct 2014 2:42pm
Googsy
Heres me thinking this was a post on viagra Very Happy Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #289187 27th Oct 2014 2:47pm
Errr...
https://www.machinemart.co.uk/shop/product...-drive-met
Post #289192 27th Oct 2014 3:21pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Re: How Hard is it
Cant you get the 19mm deep one and either..
a) stick a 1mm shim down the socket
or
b) Grind 1mm off the end?
Mr. Green
Post #289194 27th Oct 2014 3:38pm
WTF are you going to do with an 18mm deep 3/8 socket? Shocked
Post #289195 27th Oct 2014 3:47pm
@ NDF .. Checked them out earlier they told me 3-5 days delivery .... needed asap
Anyhow , got one from a local tool store only to find out the depth of the deep socket is still too short for to tighten this specific bolt up ....
Aw f Censored k Censored Censored Censored
Post #289208 27th Oct 2014 4:51pm
To put you in the picture
This is the Deep 18mm socket at its maximum reach , the hex nut you see has to be tight against the top of the bolt .....
Problem being as in picture below the bolt you see goes in at the top of this bracket the hex nut goes in at the bottom so the deep socket cannot tighten the nut up as its an enclosed space
Maybe try looking out for a Rothberger spanner ...
Post #289209 27th Oct 2014 5:01pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
I'm intrigued Mick...what you trying to tighten up? Confused The forums premier drug dealer and human trafficking consultant
Range Rover Vogue SE 4.4 TDV8, Range Rover Sport HSE 3.6TDV8, Audi S8 V10, Jaguar XKR Conv, Jaguar XJS V12 Conv, Land Rover Disco 3, Lexus LS 400 MkIV, Lexus LS400 Mk III.
Post #289210 27th Oct 2014 5:06pm
Can't disclose that on here Jim .... Laughing Whistle
Post #289211 27th Oct 2014 5:09pm
Well it's certainly not his nuts, no way are they big enough to fill an 18mm socket Laughing Laughing
I'll go out to the garage and have a look Mick, would a 1/2" drive be of any use if I have one? I can supply a 1/2" ratchet or breaker bar or T-bar also
Post #289212 27th Oct 2014 5:31pm
PaulTyrer
My dad used to have a full set of box spanners that you could tighten up with a T bar, probably about as much help here as a chocolate fire guard though!
Post #289213 27th Oct 2014 5:33pm
Cheers John , will let you know my Son is going to call up later with some concoction he has come up with regarding spanners ....
Should be fun , have to get this sorted before wifey comes back from holiday on Wednesday Rolling Eyes Rolling Eyes Laughing Laughing
Post #289215 27th Oct 2014 5:42pm
This any good fannybaws?
18mm deep 1/2" drive socket
Can supply the following to fit it
Ratchet
Breakerbar
T-Bar
Impact wrench
Torque wrench
and possibly a few more bits and pieces Laughing Laughing
Post #289217 27th Oct 2014 5:43pm
I'm just wondering if the extending wheel brace doesn't have an 18mm end? Got - 2017 SDV8 Autobiography in Loire Blue
Post #289220 27th Oct 2014 5:59pm
