Home > General (L405) > Has anyone fitted an OBD port lock? |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I read with some disquiet about the hacking of the keyless entry systems on the L405. They might become uninsurable.
27th Oct 2014 4:11pm |
The easiest/best way to protect an OBD port is to simply fit a switch into the earth wires at the rear of the port itself with the switch located somewhere only you know. This disables the port and would make it almost impossible in a reasonable time for any potential thief to successfully use it. For absolute security you really need to do the modification yourself.
27th Oct 2014 6:26pm |
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 |
My C63 was stolen via 'key cloning'. Insurance / police and tracker all said USB was most common on BMW but effects all vehicles, re insuring L405..... Just renewed mine £575! That's taking into account the opening sentence of this post! |
27th Oct 2014 7:43pm |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
Just be very careful with anything to do with the OBD port - I have tried a couple of OBD solutions recently, and they have kicked the vehicle into diagnostic mode without me realising and disabled the ESP completely without showing a warning light, as the vehicle is assumed to be stationary ion diagnostic mode. 4.2 Supercharged Vogue SE |
27th Oct 2014 10:08pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Remove your original OBD socket and hide it behind a panel/cable tie it up behind the dash... Then go to a scrappy and cut one out of another car and refit it in your now absent hole
28th Oct 2014 12:20am |
Mark1107 Member Since: 20 Oct 2014 Location: Los Angeles Posts: 106 |
Here's what I don't understand, corvette since 2005 has keyless entry but the fob has a rolling code one of a million combination and even if they can pick up the code it changes each time you activate the fob and it's very difficult to steal our vettes. Why can't jlr do the same thing? |
28th Oct 2014 3:29am |
Mark AFAIK all modern cars use the rolling code thing. The tricks that are being used are different and much more high tech than blunt code cracking.
28th Oct 2014 6:12am |
I just had a better idea. The "fake" OBD port should be fitted with a small ECU that first install a bit of software onto the laptop that makes the laptop send continuous messages about its location. Also the fake OBD should activate a tracker unit (separate from any other trackers) that alerts the tracker company and the police that someone is fiddling with the car.
28th Oct 2014 7:14am |
Thank you ebajema for the clarification. It's amazing that these tools are available to steal from hard working owners very expensive and difficult to obtain cars. This is an epidemic on your side of pond and I haven't heard about it once here in the USA....I don't own a gun but American cowboys would probably shoot the thieves. Also 99% of Range Rover owners have a minimum 2 car garage if not a 10 car garage at this price point vehicle. Mark |
28th Oct 2014 8:23am |
It is ridiculous Mark that A. it is possible to get the tools so easily, B. that is it possible to use the tools for stealing and C. these bastards seem to not like honest work and take it from hard working people (well most of the FFRR owners are/were hard working people). MY 2010 5.0 SC Galway green and sand interior!!
28th Oct 2014 8:39am |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 340 |
You must be ancient and/or live up a mountain! £575 bargain. You got a tracker on the L405? On Topic. If the want your car they will get it. Hook or by crook..... |
30th Oct 2014 7:51pm |
10 seconds to start one on Watchdog |
30th Oct 2014 10:26pm |
Hotwheels Member Since: 20 Jan 2014 Location: Surrey Posts: 62 |
A friend of mine had his 2013 Range Rover vogue se stolen like this and he had terrible trouble with the insurance company as they claimed he must have left the car unlocked!!! Plus he lost his no claims and his premiums went through the roof (protected no claims made hardly any difference) so this is definitely going on, I have now had a protective device installed in both my cars which dosnt affect the way I open close and start the car but protects against this type of crime (don't want to elaborate incase the wrong people are reading this) it was done by a company called select auto systems and only cost £200 per car. Bargain compared to what it would cost to loose my pride and joy!!!!! Great job from a very nice installer called Gary very fast prompt and above all careful installation (apparently he works for all the leading prestige car manufacturers and it shows in the care he took whilst fitting, with me looking over his shoulder!!!) contact www.selectautosystems.co.uk |
31st Oct 2014 9:11pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
people should also be very aware of say, a 'company' in say a car park, with say an advertising tent etc, giving free paint /dent repair quotes, they will obviously have you looking at your dent, while the other guy 'reads' your paint code, via the OBD in a few seconds, they might then even ask where the quote might be posted to!
31st Oct 2014 9:20pm |
