![]() | Home > Technical (L322) > Tow Bar Question |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
The FFRR armature takes a square receiver type drop plate tow hitch - this is bolted to a backing plate on the "hitch" and can be removed to replace it wih anything else that will fit into the same bolts positions. I converted mine to take a Freelander1 Bike rack and I can still use it as a tow hitch as well as the bike rack is mounted on a plate between the backing and drop plate hook. This is what it looks like
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
is this what you need..
At least it's about 1/10th of the price of the one I posted! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
its cheaper than the OE one also on ebay..[£250] ... - .- -.
Discocuzzy Member Since: 02 Aug 2010 Location: Surrey Posts: 94 ![]() |
I dont need the drop plate as i have a reciever that the nato bolts to which is 2", it looks like i will just need the main assembly |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
Then you will need 1 of these then:
mmm not sure...thats just the tow hook isnt it?...i need all the metal work that mounts to the chassis with the square connection ready for me to mount my reciever/hitch.
It looks like what you need is the armature, basically it's a subframe that has the square receiver built into it and bolts on under the car - it was LRs attempt to make one system for all markets and has interchangeable fittings that go into the square receiver. I will scan the picture of it in the morning and also take a photo of what is on my car 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
D.C. i have the complete RR towbar that goes into the 2'' hole that i'm willing to flog, is that what you need... ... - .- -.
Oooh..yes it is scarey, thanks Tim for the pics |
pm'd you D.C. ... - .- -.
