Home > Technical (L322) > Check coolant warning query
Knightrider
Hi guys the check coolant warning came on in my car on saturday, it took approx 1 litre of distilled water to get it back to a normal level. I left the car for 24 hours and rechecked and the level was the same as when I topped up and there was no sign of a leak.
I wanted to ask if the 4.4 petrol engine is known to lose coolant over time or do you think I have a leak somewhere, I last topped up about 6 months/4000 miles ago.
Also the coolant is red/pink, to keep the right concentration of antifreeze can I use any red coolant say from halfords?
Thanks in advance for any advice. 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #291927 10th Nov 2014 7:36am
yours is 10 years old so there might be a possible leak somewhere or the coolant cap might be of the wrong pressure rating [search the forum for that info] ... - .- -.
Post #291944 10th Nov 2014 10:04am
Wow, your one of the lucky 4.4 drivers then sir Whistle Whistle Whistle As they get older, they seem to mark their territory more & more Laughing
Yes you can top up with orange antifreeze from anywhere sir...
Post #291946 10th Nov 2014 10:08am
Knightrider
Thanks for the advice, I will monitor the coolant level over the next few weeks - hopefully it's just normal incontinence for the old girl as she is getting on a bit! 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #292036 10th Nov 2014 7:06pm
RR2008HSE
Mine looses a little coolant. I don't know where, as the system has been tested.
Check the forum for details. Possible solutions include: new coolant, new coolant sensor (v cheap), new coolant expansion tank (not cheap, around £100).
Post #292136 11th Nov 2014 3:16am
