Home > Technical (L322) > AV Input ?
pjb
AV Input ?
Hi Gents,
Can anyone advise how / where I can connect an additional AV input as I have a camera in the horse box that on my Disco 3 I connected via GVIF interface to the front sat nav screen.
I had hoped to do away with the GVIF interface on the FFRR.
Any advice etc.
Wired through 12s socket worked very well.
If all else fails then venturecam !
Look forward to your advice
Regards
Paul
Post #26143 22nd Aug 2010 12:18pm
depends what year your FFRR is...if its between 2002 and 2005 then an ibus adapter connected to the rear electronics should be ok , look on ebay for this , should cost about £40/50....if you have a touch screen then you have a M.O.S.T. fibre optic setup so an adapter for this is a lot more at around £300...in this case then a venture cam is the best option... ... - .- -.
Post #26261 24th Aug 2010 12:08pm
