![]() | Home > Off Topic > Lego trains |
Hi Guys,
No idea about the controller but I can almost feel your (soone to be) pain.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
Just checked with a guy at work who is into Lego (the big tecchie stuff) and he suggests doing a search on the Lego website. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35863 ![]() ![]() |
theres a forum for lego
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
OMG Stan I can't believe I just followed that link!
you'll be buying an anorak next!!!!
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 ![]() ![]() ![]() |
No. stepping on an upturned 3 pin plug is definitely worse than a lego brick. My Motto: If you are going to have one, have a BIG one! |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 ![]() ![]() |
If they are the digital type, you should be able to control more than one with one controller. If analog, you will need one controller per train. If it has an IR system, it sounds like it's digital.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
You can control more than one train (or anything with a IR receiver/motor set in it) with the controller - it has a 4 way switch which corresponds to a switch set on the IR receiver.
Controller:
Excellent stuff! Martin what do the 2 control knobs do? Can one controller do 8 outputs? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
For the trains, I don't know. But there are two outputs per IR receiver - a red channel and a blue channel.
