Home > In Car Electronics (L322) > Replacement amp
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Replacement amp
Ok I got a second hand amp from a BMW x5 to put into the FF as mine is playing up.. Sometime it works sometimes it doesn't. Plugged it in and nothing..well apart from a binging noise about every 8 secs... Rolling Eyes Does it have to be coded. Thought they were plug and play !!!!
Steve
Post #295187 25th Nov 2014 8:28pm
miggit
Hi ya Bud, have you read this thread?
http://www.fullfatrr.com/forum/topic28194.html
It would seam to me that this is of a similar problem, all be it with the Logic 7 amp, but from what I can make out it's the same system, only better (ish!) Thumbs Up
I would imagine that it's looking for some thing that was in the BMW, but is not in the FFRR! Sometimes I think it may have been easier if they'd stayed at the Classic level of ICE Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #295306 26th Nov 2014 4:32pm
Steverr
Where can I get it reprogrammed does anybody know or had it done? What are the costs involved ? IID ??? Razz
Post #295344 26th Nov 2014 8:38pm
mjdronfield
Have a look at Navcoder. It's for the BMW systems.
That could do it, but double check before you get a cable etc.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #295360 26th Nov 2014 10:27pm
Steverr
What he ones on the bay ??? http://www.ebay.co.uk/itm/BMW-USB-Diagnost...43d2da57aa
Post #295479 27th Nov 2014 6:23pm
mjdronfield
Looked on the net, and I'm not sure Navcoder can do DSP coding. Does everything else though.
To answer your question, that's the cable I got and it works fine with navcoder.
Not used the other applications that the seller has bundled with it.
The cable will work but I'd check you can do what you want with the software.
I put navcoder dsp coding into Google and a few posts indicated it was a no go...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #295486 27th Nov 2014 6:47pm
Steverr
Censored Censored Censored thanks Thumbs Up
Post #295493 27th Nov 2014 6:57pm
