Home > Technical (L322) > Transmission fluid leak
n1cktdv8
I noticed a mark on my drive, no bigger than palm of your hand and clear. Had a look underneath and seems to be coming from the transmission filter?
It's going in for a full gbox/diff/oil service over the weekend but this has only just begun to happen, any ideas ? Is this where I put the car details and a bit about myself ?........
Post #295287 26th Nov 2014 1:24pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Doubt it will be transmission related if its clear - IIRC transmission fluid is red, are you aware the air-con system discharges condensed water from the air via pipes either side of the g/box? - probably that I'd think
Post #295317 26th Nov 2014 6:10pm
n1cktdv8
It looks like a weep on the filter plug too me. Doesn't taste like water either Big Cry Is this where I put the car details and a bit about myself ?........
Post #295321 26th Nov 2014 6:41pm
seal on the electrical connector has probably failed, search, think it is a fairly common problem..... (or that could be gm box, but seem to recall ZF) Quite a cheap fix esp if you are having the box filter and oils done.
hence why it is oily round it, if it was the drain plug it would be unlikely to have tracked upwards Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 26th Nov 2014 6:59pm. Edited 1 time in total
Post #295322 26th Nov 2014 6:56pm
n1cktdv8
I think it's the ZF. The filter kit and all associated areas are being done. I'll add this to the list !
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #295323 26th Nov 2014 6:58pm
http://www.fullfatrr.com/forum/topic14798....rical+seal
have look at that thread, you can see how the seals fail. There is nothing that can't be fixed with a hammer😜😜
Post #295326 26th Nov 2014 7:10pm
n1cktdv8
Great read, though way beyond my skillset. It does look a standard problem, mechatronic sleeve leaking. As the filter is coming off I'll have them check and change whatever is needed.
Cheers Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #295328 26th Nov 2014 7:18pm
Worth doing gen part is less than a tenner Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #295331 26th Nov 2014 7:47pm
n1cktdv8
My mechanic geezer is ex LR/Jag so he always uses genuine Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #295332 26th Nov 2014 7:55pm
