![]() | Home > In Car Electronics (L322) > Heated seat repairs? |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Has anyone tried using a lower heat pad say off a jag or rover under the leather cover then wiring it into the plug as its a two pin the same? Something like this pad
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8752 ![]() ![]() ![]() |
Just fitted a set of these to my daughters Smart Roadster, they are very quick and hot and you can cut them to fit, you get four pads, two would do a full seat base, the only problem I can see is that the temp probe is in the original seat base pad, it may work without it.....
