![]() | Home > Maintenance & Mods (L322) > Brake discs replacement |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
If in doubt n brakes i would change them. i cant remember exactly when i changed mine but i think it was around 40,000 miles. Generally it depends on your driving style and the sort of journeys etc rather than mileage. If there is a lip on the Disc it sounds like it is tome to renew especially if paid for by dealer |
kin Member Since: 20 Nov 2008 Location: rainy city Posts: 348 ![]() ![]() ![]() |
Thanks, but somehow I got a feeling that it would not be replaced as this service is FOC... |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
as for gearbox oil for the sake of a couple of hundred quid itll give peace of mind and saves the cost of a gearbox overhaul at like 2k money well spent onto no6 Range Rover
Does it really cost a couple of hundred pounds just to change gearbox fluid? |
thats pretty good when you consider what you are replacing youve got a big gauze filter a few seals and a new pan gasket then the oil which i believe you cant use std ATF red fluid i just get everything from LR the fluid is bout £100-£150 could be really special but i doubt it the only reason i get it all from LR is i know it all pukka and tested stuf onto no6 Range Rover
Ahh..I see, I thought it has a drain plug at the bottom, and a fill plug somewhere half way up. ...so it has its own oil filter, and it does not have a drain plug? Is that right? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
If like me you're used to working on old Land Rovers then yes it was just a case of a drain plug and a filler hole, dead easy!
Well...took it down today for a free service, and asked for the gearbox fluid change, he told me fluid alone would cost in the region of £110-£120. I guess the fluid must be really good then, anyway I've told him to go ahead, and also have those side steps fitted as well |
read this first...
Thanks again |
Sadly I don't, but the Indy I take mine too is NOT a Land Rover specialist, you don't need to be to fit brakes, any grease monkey can do those.
I also had my Pads / Discs done by the local friendly garage - Far cheaper and more reliable - Dont Forget the Brake Sensors though?!?! ithink from memory they were around £12
They quoted me £400 fitted, as part of the deal of buying the TDV8 ![]() BTW someone over in the PH forum recommended this Landrover indy http://www.a1-landrover-specialists.co.uk/ Anyone has any experience with them? |
