Home > My Range Rover > Proper load lugger!!
RiccartonRR
Went and collected 8 big bales of hay. I wrap them from the underside with a tarp' to stop spray getting to them off the roads etc.
Apparently, according to my supplier, not everybody takes 8 at once behind a 4x4 - but then I did point out that not everybody drives a Full Fat Very Happy
Post #296635 2nd Dec 2014 10:34pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
That's a "Good load".......
Post #296638 2nd Dec 2014 10:37pm
nice 'country side' pic that.. Thumbs Up ... - .- -.
Post #296651 2nd Dec 2014 10:56pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Bet that is over the 3.5 tonne trailer weight Thumbs Up
Quite often forget I have my trailer on the back if I don't have weight on it 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #296652 2nd Dec 2014 10:57pm
RiccartonRR
Nah - it's only hay Thumbs Up Ciirca 250kg per bale so only a couple of tonne load.
I'm over weight when I bring back 6 black bales of Haylage at between 685 & 710kg per bale Whistle
Post #296662 2nd Dec 2014 11:06pm
RiccartonRR
I know what you mean - how these peeps manage that you see towing one of these wee Halfords type trailers behind the FFRR down the motorway? They can't see it, they can't feel it & by christ they can't reverse it Rolling with laughter
Post #296666 2nd Dec 2014 11:08pm
Proper working RR that. Thumbs Up
Post #296670 2nd Dec 2014 11:14pm
The smaller they are, the harder to reverse they are... I have owned a tri axle & twin axle 16ft ifor and our 7foot trailer at home is by far the hardest to reverse!
Post #296676 2nd Dec 2014 11:24pm
RiccartonRR
Mind you, the tri-axle is always ready to catch you out. If you reverse over a lump / bump / crest the turn rate varies massively depending on whether the weight is on the front or rear axle. Twins are nowhere near as bad but are still affected.
Post #296679 2nd Dec 2014 11:30pm
Yes my new one is a twin axle replacing my tri axle... I also got sick to death of the punctures in the 10" tyres... Don't know if its just luck (or lack of it) but the bigger wheel'd twin axle ifor's don't seem to have so many punctures... Rolling Eyes
Post #296683 2nd Dec 2014 11:40pm
I managed to reverse my old small trailer Craig. You don't know how to reverse properly?
I almost never had to un-hitch it and push.
....honest. :oops:
Post #296686 2nd Dec 2014 11:43pm
Bulls Censored t... Whistle Whistle Whistle
You couldn't reverse that tiddler down to my workshop sir... Whistle Whistle Whistle Laughing Thumbs Up
Post #296689 2nd Dec 2014 11:45pm
I suspect it's similar to motorcycles. With the short distance between the axles one tyre will pick up a nail and the next wheel will run onto it before it has chance to drop back to the ground.
Post #296690 2nd Dec 2014 11:46pm
Welshdragon
Very nice load Thumbs Up Thumbs Up If it dont work.......burn it!
Post #296769 3rd Dec 2014 1:46pm
I think RiccartonRR has taken many massive loads. Smile
Post #296775 3rd Dec 2014 1:56pm
