Home > Technical (L322) > Battery levels with time |
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 |
When I had a problem with my 2010 TDV8 3.6 before the factory recall Q159 corrected the software problem, the initial 'dark current' immediately after engine shut-down was 5 (FIVE!) Amps. It took over 25 minutes to get down to what I was told was the 'normal' battery drain of between 12 to 20 milliamps.
4th Dec 2014 5:25pm |
12.55V is pretty reasonable for the situation you describe. I would have expected 12.6-12.8V after a run but it really depends on the accuracy of the voltmeter your were using. At worst it would indicate slight deterioration of the battery.
4th Dec 2014 6:39pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
thank you guys.
4th Dec 2014 6:57pm |
Is the new battery an agm or standard lead acid? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Dec 2014 1:29am |
errmmm, dont know, its a wet battery?
7th Dec 2014 8:46am |
If your battery is down to 12.2V after 3 days with only a 2mA drain showing it tends to suggest your battery is draining internally ie it's past it's best irrespective of age.
7th Dec 2014 9:10am |
thanks for the reply, i think i have a greater issue, will start another thread on it. Cheers
7th Dec 2014 8:34pm |
would unlocking the vehicle 3 times a day each day over the course of the testing draw it down? Cheers James |
7th Dec 2014 8:44pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Each time the vehicle wakes up from sleep, it initially draws around 7 amps. it will wind itself down again usually about 15 - 20 minutes until it goes back into sleep mode.
7th Dec 2014 10:19pm |
i am hoping its ok, its only 2mths old! Cheers
Agree with vaz above.
7th Dec 2014 10:35pm |
