![]() | Home > In Car Electronics (L322) > Newbie with a couple of question (RR2002 Vogue) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7986 ![]() ![]() ![]() |
In my scenario, you will be cutting the rca pre amp out plugs off the head unit loom and putting the wires into the right pins on the connector on the bm54.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi I think that this is the sort of thing that you require, I have tried to find one on ebay Aus, but as I'm in the uk its proving to be a bit harder as it keeps showing me stuff in the UK, even though I'm logged in on ebay Aus??
Of the 2 connectors you have at the front of the car, some of the wires are tape output that feed the boot. You will need to look at the wiring / connector diagrams in Petes thread.
BenjaminD Member Since: 08 Dec 2014 Location: Brisbane Posts: 19 ![]() ![]() ![]() |
Looks like I could have a couple of options. My first attempt is to plug the new unit as Ironhorse did in the back of the car. He passed me some very valuable info of how I should do it. If that option doesn't work, then I guess I'll have to look into the source feeds from TAPE or CD and cut some wires (or buy connectors). For now I unplugged the cd-charger and still have the old unit in the dash.
Some pictures to make it clear what I'm dealing with. It's pretty clear that unplugging the radio-loom disconnects the DSP. I can only hope that finding where that ILL + goes would solve that (DSP + steering wheel control)
Not sure how iron horse connected up.
There's a a red (10) fuse thing in the old radio unit itself but can't see how this could be placed in the new loom. So basically you saying I should try keep one connector in the Bm54 and one in the new unit, right?
No but I thought the connection out of tape, cd, etc... had only two signals. That's what I remembered from the wire diagrams.
Which means my remaining options for that setup would be tape since keeping the CD-charger with the old unit and the new unit, I run out of space. Thanks for your feedback again |
If you look at the original bm54 connector carefully, there are 3 parts to it. Like 3 looms if you like. Not the fuse.
Update:
This is a different connector but shows what I mean. One of the sub connectors is removed....
Thanks! By watching your link, I realised that my diagram missed pin 9 on the 16pin, which is the IBuss.
Ah, just read your post....
You will need some sound feed from the new unit to the bm54 obviously, I assume that's done on the connectors on your new unit.... 2011 Range Rover Vogue SE 4.4 TDV8
