![]() | Home > Technical (L322) > Battery time. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
Top left with the red tape around the lead and the "+" on the front of it...
krisleeds Member Since: 19 Oct 2014 Location: leeds west yorkshire Posts: 60 ![]() ![]() ![]() |
Yep defo missing from mine. It doesn't drain on its own its more of like having boot open for 20 mins and then its flat. I set timed climate to come on the other morning it had been on for 15 mins and it flattend battery. Also random things like tv station memory being lost and audio settings re setting . |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Have you had the alternator done yet?
I will check the voltage as you mentiond. Intresting that you mentiond the key because thinking about it i cant remember which key i was using when i programmed the tv. The other day and have been using both. Although the battery is as old as the car its probably due one. |
