![]() | Home > Maintenance & Mods (L322) > third brake light |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
hi all
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
afaik its a led strip so the whole thing needs replacing...also i didnt know that the two rear side breaklights are leds as well [according to the manual]... ... - .- -.
interesting tim, so if one fails is it an expensive job... ... - .- -.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
How long have you been owning Land Rovers scarey?....................................... Haven't you noticed that almost anything that has the LR oval stamped on it is vastly overpriced. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
about three weeks tim.....but i get your point. ... - .- -. Y. O. L. O. . |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Unusual that the whole thing's stopped working, might be worth checking the wiring to it if you're handy with a multimeter?
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
Any 1 know where it picks it's feed up from? |
thanks all as usual a fountain of information given
@nigel... acording to rave it looks like its fed from the LCM [light check module]
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Amazed it has gone wrong, LED lights are usually very long lasting, I've never seen a faulty one.... Discovery 4 HSE
Cheers Scarey
hope this helps...
