![]() | Home > General > No Drive |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Has it had the prop shaft recall / enhancement (according to our local service manager). |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
100% Diff/shaft mate......should be covered under LR recalls. |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 ![]() ![]() ![]() |
it has definitely had the diff done as I checked the history out with the main dealer before buying
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
IIRC there is a small plastic linkage in the shifter mechanism, I wonder if it has given up the will to live? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 ![]() ![]() ![]() |
Front Diff. it may have been replaced in the past:-
Yes as above.....mine on my old TD6 was replaced then about 18 months ago had a recall for a "newer" fix FOC. |
Oh yes and when they did the recall they refunded all the money I had paid the first time it was replaced so I was very happy about that too |
thanks for the help fellas, so its definitely the diff? Should I get it check by the indy before getting on the phone?
or gearbox....
or gearbox....
both have the same symptoms, ie no drive.
OK ,, if you get under and take a looksey , if you have a UJ at front and rear of the front prop then it has the new prop modification. I doubt this is the case from what you say so far so its likely you only have a UJ at the end where the prop links to the gearbox.
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
That sounds expensive. ![]() |
