![]() | Home > Technical (L322) > Heated Front Screen Operation |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
dont think it is for yours andy |
you didnt think that owning a FF would be easy ,did you? |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Don't I know it Mate! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Right, so before I took things apart I gave the interior of the screen a good clean and then got some freshly boiled water in a container and moved it about on the dash (slowly!) until it was all steamed up, started the engine, fans off, just the screen heater on.
And it didn't clear on the sides outside of the heating elements, so I think its all ok. Discovery 4 HSE
try cling film Adam.. ... - .- -.
Stan...for what? Discovery 4 HSE
Or rub a potato (cut surface) on your windscreen in the evening, the outside that is. The sugars of the potato are supposed to stop the screen from freezing over |
place on windscreen, turn on the heated screen and watch the cling film curl up [if working ok] ... - .- -.
I actually used the "bubble-wrap reflective" sunscreens (I had one that had "wings" that went in through the door) on the windscreen. That kept is pretty clean every night. Just the hassle of putting it on and into the car (wet) was a bit annoying but still, kept the screen clear on frosty nights |
Stan. Cling film outside or inside? Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
outside |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
Glad I don't live in London or park on the street and of course glad to be retired.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
When I switched on the screen heating (not often needed) I noticed a slight trembling (as one would see above hot tarmac in the distance) that would disappear immediately when switched off . Anyone noticed that? Is that normal? I find that irritating.
