![]() | Home > Maintenance & Mods (L322) > strange noise in dash after opening door |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
many people have had this or similar squeal noise, cant confirm here, but its often the fan in the engine ecu box, under the bonnet. there is a pipe that it draws air from the cabin, via said fan, to the ecu box, that appears to direct the noise back to the heater aera. if you hear it, and quickly thump the ecu box, (before it times out) if it changes pitch or stops, then it safe to say its the fan. there are threads showing how to remove ecu's and fan and grease it, as its all thats needed. a new fan is small/simple but expensive though. its like a 2 inch pc fan. |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Yep, sounds like the ECU fan! But I will say that I experienced something very similar in the car that the garage lent me while I had multiple gearboxes. It was a Merc 4 door thingy with a diesel lump and horrid turbo lag, nothing special, anyway every time I turned it on it would clunk and whir for a while and then shut up. Wasn't too worried, wasn't mine.
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Naw, clicking is not the ECU fan, it will likely be a bad gear in a stepper motor - just like you diagnosed, Balki.
Could it possibly be caused by a Tasmanian Devil trapped behind the dashboard? |
| Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35
tassie devil, i must feed it so it shuts up, thanks fo rthe advice will look at steeper motor |
so would this motor run as soon as you open a door? |
