Home > For Sale & Wanted > SOLD £17, 500 Def 90 trayback race ready
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
My trayback is up for sale, just thought i would link in here in case any one was thinking of taking their off roading a level one from RRFF off roading.
Its not a RR so not in the FS section as per the rules.
[For Sale] 2.8TGV auto 90 Trayback, Ashcroft Force 9s
Well known Trayback for Sale. Built for reliability and ease of serviceability/commonality of parts.. I built this with the help of Ben Proctor my codriver back in 2011.
Since then it has done 22 events, and finished all of them, always been placed 9th or higher (IIRC) with some 1st, 2nds and 3rds. Completed KoV (Jul 12), All 3 De-Ciders since build, both Welsh Xtremes, with the rest made up Mad Monks and some local events. Last raced coming 3rd in Jul 14.
Fully serviced and maintained post each event, no expense spared, comes ready to race as below and with spares kit (Priced around £1,5K) that I have taken to events.
Everything is fully working, cars comes serviced and with MOT expiring 30 Aug 2015, its ready to race.
Reality is I don’t have the time to compete as much as I would wish and am going to go back to concentrating on codriving, will be in with Jerry Hunt in a Gigglepin Car for 2015 so am going to be busy!
Plenty of clips and pics of it out there if you search for events as above or under me.
Full build pictures are available if required, email me with specifics. info@4x4adventures.co.uk
Vehicle
93 chassis doner vehicle, rebuilt at 23539 miles showing, done 618 miles since (at 31 Aug 14). V5 engine number correct.
Cage
Roll cage and tray back, part North Off Road (small part!)
MSA compliant (KoV etc when was MSA)
D44 harness mounts
Front Wings
NOR Extreme Challenge Wings
Cooling
Allisport rear fitted rad (V8 spec)
with twin fan setup in Allisport shroud
twin (32 row and 24 row) gbox coolers, engine bay mounted
^^with dedicated fans on each
Engine
Approx 45k miles 2.8 TGV with variable geo turbo
oversized front intercooler
Front Winch
Gigglepin adventure Twin top
Delta Tek Free spool +3 "
Delta Tek +3 stainless fairlead
Gigglepin uprated mainshaft
twin Bowmoter 3s @ 9hp each
8274 bottom housing
Rear Winch
Single motor top housing
Single Bowmotor 3 @ 9 Hp
8274 bottom housing
Transmissons
Gwyn Lewis WA props
LT230 1.6 ratio
Ashcroft Monster Auto box HP22/24 amalgamation
Brakes
110 Caliper throughout + complete spare set
Llama braided custom hoses inc spare set
Wrex Racing Fiddle brakes
X-Eng Disc Handbrake
Electrics
4 Batteries 105AH, 1000CCA
12 v vehicle and winch system
24v switchable winching
3 way switchable fan coolers
Front and Rear lighting switches
Axles Ashcroft Force 9s
9" undirectional diffs
Std LR Def hubs and PCD
X-Eng Rear Adjustable Arms
Std Front arms (clocked swivels)
Fuel
2L bulkhead mounted swirl pot fed electric fuel pump
custom 60L (?) ali rear mounted tank
Suspension
D44 dislocation setup
King remote res +5 front shocks
+5 OME rear pin pin
4 of 2" King hydro bumpstops
Air System
ARB compressor
Gigglepin Manifold
Redundancy solenoids 4 of
90/120psi pressure switching
Wheels
5 x ART double beadlock with valve protections and outer rock rim reinforcement
1 x single outer beadlock rock ring
(total 6 rims and tyres)
Tyres
6 x Fedima 35x10.5R16s, 90% tread left.
complete with Rock Rash!
Navigation
Two 203V3 Terratrips mounted via DIS system
DiS controlled
Steering
Std LR 4 pin Pas box
Gwyn Lewis Ram assits
Gwyn Lewis Xtreme Sumo Disco Track Rod
Gwyn Lewis Xtreme Sumo Disco Drag link
Gwyn Lewis track rod protector box section
Seating/Safety
Exmoor Trim Mesh Seats
4 point 3" harness MSA approved 2013
Spill Kit
Fire Ext MSA approved
Storage/Kit
Waffles
Strops
2 x Peli cases
Double hooks
Highlift Jack
Stump Hook
Full Spec as above, parts alone are around £34k. Looking for £25k complete as is with spares pack, ready to race.
Will not break, if you wish to make an offer on a part then its £25k for that part, it will come with all the other parts and you are welcome to sell on the bits you don’t want! Cheers
James Cheers
James
Post #300140 20th Dec 2014 9:49pm
JST
some older first outing pictures
 Cheers
James
Post #300141 20th Dec 2014 9:49pm
JST
Just won the red Winch Challenge. Cheers
James
Post #300142 20th Dec 2014 9:50pm
JST
just won its next event - Driven to the Edge
a comp safair with some proper off road sections!
Open to offers, package can be adjusted to suit price, Cheers
James
Post #328678 19th May 2015 8:44pm
Great truck James, the spec list is like a wish list....
I'd love it to off road with but unfortunately I don't think it would be any good without a heated steering wheel... I've been spoiled with the FF.. Laughing
It's also far too much money for me, but a bargain for someone.... Pete
Post #328685 19th May 2015 8:57pm
One hell of a truck mate Thumbs Up
Post #328688 19th May 2015 9:17pm
Welshdragon
You retiring like I have or you building something buggy type as these challenge events get tougher for the trucks?
I know the 90 Wink well specked too Thumbs Up If it dont work.......burn it!
Post #328696 19th May 2015 10:01pm
Martin
Site Admin
Moved to FS section, not an RR but ads should not be in OT Wink
Post #328704 20th May 2015 7:40am
JST
thank you Martin, i didnt want to put it there due to the rules but makes sense its there.
no not retiring, i am doing more codriving of late and time is limited. if it doesnt sell i may keep the main parts and buggy it with time. at the moment though i would loathe to do it as itsd a package that works really well.
its never had a mechanical failure resulting in not finishing an event. got to be one of the most reliable challenge trucks out there.
thank you for kind comments. Cheers
James
Post #328860 21st May 2015 9:07am
JST
Reduced to £17,500 as above complete with spares pack, ready to race for weekend. Suitable to MSA events through to punch hunt events.
Selling as its time to move on. Crewing for Gigglepin team now and just not enough time to do everything. Cheers
James
Post #356171 10th Nov 2015 11:08pm
JST
£15,000 no spares pack ready to race/compete. Ideal vehicle for punch hunts, special stage events, Driven to Edge style events.
or axles and tyres £6,500
Winches £2,500
Rest of of £6,500 Cheers
James
Post #378566 20th Mar 2016 9:20pm
JST
Going on ebay despite just winning Interclub16 at the weekend, not bad for a vehicle thats not been used fro 18mths in comps! Cheers
James
Post #387862 19th May 2016 2:53pm
JST
Sold Cheers
James
Post #418870 20th Dec 2016 7:15pm
