![]() | Home > Technical (L322) > engine lumpy |
fil b Member Since: 08 Nov 2013 Location: poole Posts: 14 ![]() ![]() ![]() |
Hi all, my vogue l322 sometimes juddery when in idle in drive but ok under normal running/ acceleration, rev counter not fluctuating either seems to be using bit more fuel also, any ideas? |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 ![]() ![]() ![]() |
I had the same symptoms and have started this process ^^^^^^ and am already seeing some good results.
Especially with the cold weather, the diesel is a bit more viscous so you could be on to something here. I would certainly do this as the first attempt to solve the lumpiness. MY 2010 5.0 SC Galway green and sand interior!!
