Home > Technical (L322) > Tailgate issue
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Tailgate issue
The bottom part of my tailgate, to be able to close it I have to slam it pretty hard, once it's closed if I pull both ends the left side comes away as if it's not being held shut, where should I start?
Post #301242 28th Dec 2014 11:47am
catchs ? ... - .- -.
Post #301245 28th Dec 2014 11:56am
Jammer600
By catch's you mean the black things on either end? If I push the release button they both move as if powers pressent👍
Post #301246 28th Dec 2014 12:00pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Had the same with mine...had to adjust the keep (the bit that is on the car not the tailgate) as the latch on the tailgate wasn't hooking the keep correctly, leaving one side loose.
Its simple enough. Just loosen the allen head screws and move it out a little. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #301248 28th Dec 2014 12:20pm
Jammer, first job to do is to look at the top of the catches... There is a "pull up" plastic catch on the top! with the lower tailgate open, put your finger underneath and lift the two catches up... Then close the lower tailgate (without slamming it) and see if both catches lock... If they do now... You have a catch lock issue sir... If no difference then you probably have an alignment issue sir... Thumbs Up
Post #301250 28th Dec 2014 12:39pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
I had this exact problem today at the shops.
I removed the plastic trim which is held on with 6 cap covered screws (powerful uk have a vid)
Popped the carpet covered bit off.
Doing one side at a time,
Removed the 2 torx bolts holding the latch in place
Removed the latch and sprayed so pious amounts of wd40 / gt85 and left it to soak a bit
Removed the tailgate strap
Removed the actuator mounting and cleaned / sprayed the motor / gubbings
Went back to the latch and sprayed it some more to clean all the dirt out. Keep spraying and working the mechanism / plastic catch until it's free and returns smartly.
Do the same t'other side
Then put it all back to get her with some copper grease on the strap bolts
Should all be working again.
Jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #301412 28th Dec 2014 9:00pm
Jammer600
Thanks all, craig, if if move the plastic bit, it the closes properly, I snapped the one off the other side last year but that one seems to work 👍
Cheers
Post #302160 1st Jan 2015 9:35am
