Home > In Car Electronics (L322) > No Phone LED
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
No Phone LED
Looked but can't find any similar posts.
Regular 2002 head unit with sat nav. Upgraded the telephone ULF a year ago for a Bluetooth module and been working fine.
Today I couldn't answer the phone using the steering wheel button, then noticed the normally green flashing light on the top of the head unit was doing nothing, I remember before I upgraded it was always a red flashing light but that also was gone, just dead. Checked fuse 8 & 22, all fine and everything else is working. The white "telephone" text does nothing on selecting
And I'm now stuck what else to check if anyone has any pointers ? 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #303021 6th Jan 2015 1:09am
mjdronfield
If the text on the screen is still white, as oppose to grey, then I think that indicates the unit had identified itself on the ibus.
I don't really get the led lights on much. The red one comes on if my phone dies whilst connected to the car.
Short of going through all the connections, cleaning the connector, checking for water ingress.....I'm not sure what to suggest. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #303172 6th Jan 2015 8:32pm
Shandonman
10 months on and I still have not sorted this so took the plunge and bought another 2nd hand ulf. Thankfully went for a gen3 to keep the price down in case it didn't work cos guess what.........it didn't.
So I have no water ingress, presumably ok ulf, white telephone text but no flashing lights and no Bluetooth. Confused
I don't want to change the head unit as I have DSP & want to keep. Would love to have a working phone though 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #354808 31st Oct 2015 5:35pm
mjdronfield
Put into pairing mode and pair your phone again ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #354843 1st Nov 2015 10:17am
Shandonman
Tried that, the trouble is there's no pairing mode and no flashing LEDs but the text is white. I've wired in a switch previously as mentioned and it was all working fine till a few months ago.
Do you think it's worth changing the Bluetooth antenna ? 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #354855 1st Nov 2015 2:10pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Have you tried disconnecting the battery for 10 mins
Post #354859 1st Nov 2015 3:10pm
Shandonman
Yeh, I tried that, thanks for the help.
I might just try a new antenna. I see one on eBay for £15, I suppose it's worth a go.
Thinking of the wiring diagram, I imagine the ulf is connected to the head unit and the antenna and power and there's not much else could be wrong.
I had a look on eBay for a replacement head unit. I thought they'd just be a few quid but seems there's quite a market for them. It wouldn't make sense to pay that kind of money, may as well just get an android unit for a bit more. 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #354888 1st Nov 2015 7:19pm
mjdronfield
I don't believe it's connected to the head unit as such, the head unit has its own firmware loaded but it's driven through the sat nav if I remember right. The options in the menus for dsp and telephone etc are shown if that unit identifies itself on the ibus. If you disconnect the ulf does the telephone text change to grey, may take a few mins.
If you connect the ulf again and the text goes white, then the ulf is receiving power and is on the ibus.
Not sure how much could have changed if it was working before......
You should be able to get it into pairing mode without the antenna, so a new antenna prob won't help.
Strange one....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #354892 1st Nov 2015 7:41pm
mjdronfield
There is a bit on here about removing and replacing fuses, though I can imagine it'd be easier to unplug the ulf overnight.
http://www.xoutpost.com/bmw-sav-forums/x5-...eared.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #354895 1st Nov 2015 7:56pm
Shandonman
Yeh very strange.
Disconnected the ulf, text turns to grey, reconnect, turns back to white.
The mention of sat nav is a clue though as it was playing up before. Maybe a red herring though but I disconnected it once it had powered down, ckeaned & checked the connectors, plugged back in but still the same.
If I could find more info on the LED,s on the head unit, what they mean, what powers them, that might give us more pointers 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #354910 1st Nov 2015 8:56pm
mjdronfield
ULF manual
http://www.fullfatrr.com/gallery/albums/us...Manual.pdf
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #354917 1st Nov 2015 9:04pm
Shandonman
Thanks for the manual.
Left the ulf unplugged overnight but still the same this morning.
Come to think of it, battery was out a few weeks ago for a new alternator so I suppose that's the equivalant of pulling all the fuses.
Gonna have a look at some BMW forums and also double check my re wired ulf plug in case of any loose wires. 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #354991 2nd Nov 2015 1:46pm
mjdronfield
The only other way to force pairing mode or look at other bits is by using navcoder. You will prob have to buy the full version and the lead. Pity you are not nearer......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #355029 2nd Nov 2015 7:23pm
