Home > Technical (L322) > ENGINE STUTTER 2005 TD6
jinx1959
Scotland 2005 Range Rover Vogue Td6 Buckingham Blue
Hi guys, looking for a wee bit of advice. Was travelling up from Manchester today. Thursday 11.December. heading home from airport. Weather cold and snow on roads in some areas.Car ran strong and smooth from Manchester to Gretna. Had just less than quarter of a tank of fuel and due to weather deteriorating and the thought of delays due to snow. I stopped at a garge and put in £50 worth of diesel. As we travelled up towards Beattock summit. Snow on road. car ran fine for 50 miles or so then when I tried to overtake. Rev counter over 3000 car wouldn't respond and although revs increased speed started to drop. I let off hard accelerating and she ran well again. She ran fine aslong as I didn't try heavy acceleration. Everything seemed ok then after another 50 miles or so I again tried to overtake. Revs raised to 4000 nothing happened and engine seemed to stall again slight judder. I let off acceleration and again she ran fine. Got me home without any further incidents. Can anyone suggest whats going on. The engine idles perfectly and revs perfectly when not under load. Could the cold weather 1.5 degrees or snow be the cause Exclamation
Post #298447 11th Dec 2014 10:02pm
When did you last change the fuel filter?
Post #298469 11th Dec 2014 11:18pm
Agreed... Filter or pump?
Post #298495 12th Dec 2014 12:47am
If the rev are increasing but the car is slowing its not the engine is it ? I would lubricate you gear linkage first it could be simply slipping out of gear , very common for the linkage to get a but gummed up and stop it engaging cleanly and a simple job to do . 2008 MY Supercharged
Post #298505 12th Dec 2014 1:38am
jinx1959
Hi guys the fuel filter was only changed 2000miles ago.
Post #298522 12th Dec 2014 8:44am
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
Just had this on mine, it was the low pressure fuel pump, it has been replaced with a genuine LR one and all is well again Cool 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #298604 12th Dec 2014 4:03pm
Agree on the fuel pump too but also check turbo inter cooler hoses, as the extra boost from booting the throttle could force open a hole which is not open at lower boost levels, reducing performance significantly. There is nothing that can't be fixed with a hammer😜😜
Post #298691 12th Dec 2014 9:54pm
jinx1959
Engine Stutter
Thanks to everyone for the advice. I changed the low pressure fuel pump and changed the fuel filter. Car is now running ok.
Post #303132 6th Jan 2015 4:36pm
