Home > Technical (L322) > Headlight warning buzzer
RCusden
Wales
Hi, I'm trying to find out should my ffrr have a buzzer warning for when the lights are left on and the key is out of the ignition and the door is open ? Mine just has the message come up on the dash is this right ?
Thanks roger.
Post #303939 9th Jan 2015 10:32pm
mine just does a "bong of doom" just a single one.... keep meaning to stick the IID tool in and see what the options are... Pete
-Click here for Thread-
Post #303942 9th Jan 2015 10:38pm
RCusden
Wales
Ah cheers Pete looks like mine has been switched off as it can bong when you don't want it to.
Post #303944 9th Jan 2015 10:45pm
miggit
Easy way of checking the Bong Of Doom is to put the key in the ignition and without turning it open the door, all merry Bongs should ensue, not just one, it fact more like a pink fit Shocked Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #303967 9th Jan 2015 11:55pm
DMRR
All off by default on mine .... which was a relief! I mean :
1. Lights are automatic - so they go off with key off.
2. The doors open and the key is in the ignition - I KNOW! Why not just stop me opening the door like you stop me taking the key out if I forget to move to PARK?
3. If I forget the above I need to be locked away Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #303987 10th Jan 2015 1:09am
miggit
Tell me about it! There are times when you are in a hurry to get inside (mainly having been caught in traffic with the services in your rear view mirror Shocked ) and you pull up and throw the door open and go to turn off the car at the same time, Shocked Shocked Shocked Shocked Shocked
And it's not like you wouldn't realise that something was a miss when you tried to lock the car, pressing your thumb and two fingers together don't quite work, you need the key in between Shocked Embarassed Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #303993 10th Jan 2015 1:34am
RCusden
Wales
I don't get that when the key is in the ignition with the door open, which sounds like a blessing. Looks like I will have to get an iid tool and look at what the last owners have set things as.
Thanks for all the info Thumbs Up
Roger
Post #304017 10th Jan 2015 10:56am
Or the "bonger" in your dash binnacle has failed sir!
Post #304020 10th Jan 2015 11:21am
RCusden
Wales
I get the boing when going between hi and low ratio and had heard the boing plenty when the suspension compressor was playing up. Who knows it must be one of the joys of owning a range rover.
Thanks roger
Post #304040 10th Jan 2015 12:11pm
RCusden
Wales
I think you might be on to something with the "bonger" being broke, as I had to use low ratio yesterday and no bong. Next question where is it ???
Thanks roger
Post #306457 20th Jan 2015 11:00am
Never looked but remember seeing a cluster of holes (like a speaker) on the binnacle so guessed it was there... Thumbs Up
Post #306460 20th Jan 2015 11:06am
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
I get several bongs and warning message: key still in ignition. Does anyone know how to shut that anoying sound of? Cheers L322 Vogue 2003
Post #306602 20th Jan 2015 11:17pm
miggit
Err, Whistle , take the key out of the ignition switch Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #306625 21st Jan 2015 12:24am
Buy yourself an iid tool sir, you can switch them off via the CCF files sir Thumbs Up
Post #306628 21st Jan 2015 12:28am
Starberg
Got an all comms but seems indeed that i need an IID tool for this job, okey thanks! L322 Vogue 2003
Post #306669 21st Jan 2015 9:57am
