![]() | Home > Technical (L322) > Help!! No reverse!! I'm on holiday....will I drive FF home?? |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169
Oh and what might be of interest to those who know about this problem: since some 2 months when selecting reverse the is some 2-5 seconds delay before you feel the car taking off.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
i have no idea what is wrong but hopefully someone will come along and advise but i think you have a big problem... ... - .- -.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
I'd get the fluid level checked, maybe low on oil.... Pete
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Could be that the linkage needs greasing, causes the same symptoms on the zf box. Not sure about gm box though.
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403
Pete was bang on the money... Sounds low on fluid to me... Probably has a leak and driving it low on oil will probably kill the box sir |
NO! But its the best, easiest and simplest place to start my friend... IMHO the linkage would need checking too, because if the gearbox is selecting reverse but the selector does not know its in reverse then that also could be the issue...
@Cam-tech-craig; just checked the fluid at 42 degr. C (always have my IIDTool with me |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Had a similar problem a couple of years back with reverse only and it was a crack in the valve block. Fluid pressure was lost in reverse, all forward gears were ok. Engine was revving then reverse went in with a jolt. There was no sign of any fluid leakage either. |
Thnks! Cam-tech-craig! |
No, mine is a 4.4 V8 petrol. |
Hey you guys, guess what... went to the pharmacist to buy a syringe for injecting the fluid into the filler hole. Was a very helpful guy thinking of what else may work out. He suggested to use a rectal iirigator |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Did you have to buy one, or did you already have one? |
| All times are GMT |
