![]() | Home > Maintenance & Mods (L322) > third brake light flasher |
Craig,
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
What would be the legality of either the flashing hi level BL or laser one??
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35767 ![]() ![]() |
@craig, being a chinese product the laser light itself might be rubbish but if there's an apparent problem then ,like neil i'll connect to the reverse lights or the fogs ... ... - .- -.
Having just read thro the Roads Vehicle Lighting Regulations 1989 with regard to rear stop lights, surprisingly there is nothing to stop you using a flashing stop light on your car.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Thats me stuffed then I always glare at other drivers |
@paul, these peeps claim that they are legal , as fitted to the bugatti veyron and new mercedes AMG
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
The system I see a lot in france that sets the hazzards off after a few seconds of heavy braking, it seem very effective but I dont know if it's standard fit or just somthing drivers do over here.
Stan...ta...Let the fun begin then! GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Just check the law of the land in the country you will be using these Knight Rider esque lights in... Before you get that sinking feeling in your rear view mirror |
Bomb Doctor Member Since: 18 Dec 2014 Location: West Midlands Posts: 15 ![]() ![]() |
Illegal I'm afraid chaps
the bit where it says 'special warning light' should exempt it... ... - .- -.
Definition of “Special warning lamp” as described in the Road Vehicles Lighting Regulations 1989
ok thats 2 up for you |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
That system is part of Emergency Brake Assist sir... This system detects when you brake heavily and takes over applying the brakes to their maximum level given the road conditions... It turns on the hazard lights when it does so to warn other drivers to "pay attention" ![]() |
