Home > Technical (L322) > Heated Front Screen - Fuse number
supershuttle
Did anyone get to the bottom of this and if so what is the fuse number.
Mines a MY2010 and it's not listed in the Handbook,
Why am I asking this question? well having had a new tailgate fitted neither the back or the front screen now work - is it the same fuse? Geoff
Post #305212 15th Jan 2015 9:38am
Andy B
I did check my 2010 handbook Geoff, no mention of the front screen fuse number Confused Confused Same with the online Topix manual Mad Mine currently does not heat, so I need to investigate.... SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #305231 15th Jan 2015 11:05am
supershuttle
Cheers mate and thanks for looking, I did check the handbook myself and Topix with no joy-same as you. I have front and back screen not working after some work by the local main dealer - I'll check the back screen fuse later today and see if that helps, I'll also fire up the IDTool and see if that says anything. Geoff
Post #305233 15th Jan 2015 11:30am
Andy B
Thanks Geoff, bunged the IID in on Tues and no fault showing up, so let me know if you find anything! Hopefully someone on here knows the fuse number! SDV8 AB MY 2019
Post #305239 15th Jan 2015 12:00pm
supershuttle
Also found nothing with IDTool, the fuse for the rear screen is OK - so no nearer a solution if afraid. Geoff
Post #305262 15th Jan 2015 1:18pm
how about pm'ing ducky dan so he can ask his techs the question.. ... - .- -.
Post #305263 15th Jan 2015 1:20pm
Andy B
Thanks Stan, have just PM'ed Dynamic Dan our Duckworth Man Very Happy Thumbs Up SDV8 AB MY 2019
Post #305265 15th Jan 2015 1:27pm
Andy B
Geoff, Dan the Man is on the case, seems LR techies are a bit baffled by this as well!
Cheers, Andy. SDV8 AB MY 2019
Post #305346 15th Jan 2015 8:08pm
supershuttle
Thanks Andy, I now think it's not a fuse but some sort of control box under the bonnet - but we'll see what comes back Thumbs Up Geoff
Post #305411 15th Jan 2015 11:24pm
ajac8
I asked this very question before Xmas
http://www.fullfatrr.com/forum/topic28930.html
still unsure.
hope the techies come up with something.
Tromell mentioned a relay under the glove box but I can find it. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #305604 16th Jan 2015 7:42pm
