|  | Home > Maintenance & Mods (L322) > How to bleed new fuel filter |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | You shouldn't need to bleed the fuel filter. May require a few extra cranks initially but should fire up after that. This assumes all is well on the fuel delivery system further back down the line! .
|  17th Jan 2015 3:29pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | As above, just crank the engine 3 times with out letting it start so as to fill the filter, then go for it.
|  17th Jan 2015 4:10pm |
| Rob Member Since: 17 Jan 2015 Location: south Posts: 6      | Thanks for that I really appreciate it | ||
|  17th Jan 2015 4:31pm |
| viper Member Since: 11 Apr 2015 Location: manchester Posts: 271      | is this the same for a tdv8, no bleed required ? | ||
|  25th Apr 2015 4:40pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Just stick the ignition on for 20 secs at a time 2 or 3 times to help the pumps refill the system then crank till it starts  | ||
|  25th Apr 2015 5:45pm |
| viper Member Since: 11 Apr 2015 Location: manchester Posts: 271      | thankyou | ||
|  25th Apr 2015 6:03pm |
|  25th Apr 2015 7:59pm |
| Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64      |
 What does the dead end pipe do then? Got enemies? Good, you have stood up for something in your life. Never regret growing old, it is a privilege denied to many. | ||
|  2nd Apr 2016 10:31am |
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077      | AKAIK its a turbo breather.
|  3rd Apr 2016 5:43am |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839      | If it still won't start, pull off the plastic engine cover and look for a pipe that has what looks like a tyre valve, remove the cap and push it down as you crank the engine.
|  3rd Apr 2016 8:53am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
