Home > Technical (L322) > clicking at front right of engine (as you look at it)
when i had the bonnet up the earlier, i noticed an iregular ticking from the front of the engine, at tickover.
Does a tensioner bearing sound about right. Its not too loud (nearly inaudible) and disappears as i increase the revs. though there is a point where there is a bit of a continuous noise then it goes. its not the timing guides as I've had a listening rod on the cam cover and it is silky smooth.
Any ideas. Seems to be coming from the area under the air intake pipes from the filter housing.
cheers o knowledgeable ones...... Bow down There is nothing that can't be fixed with a hammer😜😜
Post #306526 20th Jan 2015 6:43pm
Just had another listen and the mechanical fairy has been and sorted the problem while I had tea Rolling Eyes
Noise now gone. suspect it was possibly a bit of air in the system feeding through the water pump as I had just had the expansion tank out to look at chaffed hose under it, whereby dropping my stubby screwdriver into the viscous fan and having to root around for 20 mins to get the thing back out.... Banging Head
Will give it a run later and see if it returns Thumbs Up
What is the script with the viscous fan, mine seems to run when it's cold, which doesn't seem right! There is nothing that can't be fixed with a hammer😜😜
Post #306573 20th Jan 2015 9:28pm
ajac8
I get a repetitive clicking from front of engine bay when starting from cold. Cant seem to pin point exactly where. Bit strange. goes after a few mins. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #307487 23rd Jan 2015 7:51pm
my clicking has now gone. Very Happy Have a few runs now and all seems well. Bow down
think it was probably air bleeding through the system. Has been in today for the oil swap and the techs couldn't hear anything, though i doubt they listen hard. The only thing they ever seem to pick up is that it could do with a set of wipers..... There is nothing that can't be fixed with a hammer😜😜
Post #307490 23rd Jan 2015 8:04pm
