Home > Wheels & Tyres > Td6 tracking
Steveo
Td6 tracking
Good evening all I have just got a 2004 td6 that was fitted with the standard td6 18inch wheels what I tho look horrible so I have now changed them to the 19inch vogue ones do I need to have the tracking adjusted or will it be fine thanks
Post #308314 26th Jan 2015 8:58pm
I did exactly the same as you a couple of years ago, absolutely no problems at all.
No alterations to tracking needed.
Post #308318 26th Jan 2015 9:04pm
Steveo
Thanks for that I shall leave it all alone
Post #308320 26th Jan 2015 9:09pm
always worth having a 4 wheel alignment done, if nothing else it will highlight any dodgy corners where maybe a bush or 2 is a bit worn. Not strictly necessary though a the overall radius/diameter of the tyres are the same.
I had mine done at the F1 auto centre near me who have a Hunter Hawkeye, which is the recommended method......Kiwkies also have a few centres with them too. There is nothing that can't be fixed with a hammer😜😜
Post #308344 26th Jan 2015 9:47pm
