Home > Off Topic > IT Networking - query with home network speeds
mjdronfield
I have a crappy SKY broadband router that does not support Gigabit Ethernet on its ports......
I have a PS3, a PS4 and a Lacie Cloudbox NAS that do support gigabit Ethernet. They are all connected to the sky router, not directly to each other, so will only communicate at the slower speed of the router.
Ignoring at this time whether I have cat 6 cables, can I buy something so they can have fast Ethernet between then and just use the sky router for Internet, if you see what I mean ?
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #309571 1st Feb 2015 9:16am
You could buy a 1gb switch. Cheap as chips. Connect all your 1gb capable bits together and then connect at 100mb to your Sky router. I'm not sure how much traffic goes between the PSs and the NAS but you'd only benefit from the faster speeds locally.
http://www.amazon.co.uk/NETGEAR-Unmanaged-...B0000E5SEQ
Oh and some cat6 cables Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #309574 1st Feb 2015 9:28am
Or get Gigabit adsl router/modem. Something with a bit of configurability can improve your connection speeds no end.
Mine is old tech now, billion bipac, but it means I can easily tweak the snr ratios and improve what is a really slow connection to something bearable. Would work even better on a connection which was half decent!
Just coz you are with sky doesn't hold you to using their kit! I think from memory they used to send out netgear dg834gt routers which are really old hat now, but folks are still using them even though there are loads of cheap enough options out there which could improve their connection no end.. There is nothing that can't be fixed with a hammer😜😜
Post #309578 1st Feb 2015 9:45am
Thumbs Up Exactly what I've done
I got more ports - I did it because my Virgin router doesn't have enough wired ports, but same idea
Post #309579 1st Feb 2015 9:46am
mjdronfield
Many thanks.
I have a sagem router I believe, the one before the sky hub. The issue is you have to hack it to get the sky server logon, so makes changing to a non sky router harder. I may move to BT or Virgin for fibre broadband in due course....
I'm liking the switch solution. I take it that won't send local traffic to / through the router ? So could work without the sky router connected to prove the point..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #309595 1st Feb 2015 10:29am
Andy B
That's correct, only the traffic destined for the Internet will go via the Router. TCP/IP is a 'send and hope' protocol and relies on the destination device listening and grabbing the packets from your originating device. So, switch is the way to go Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #309639 1st Feb 2015 1:08pm
mjdronfield
Thanks again. Just bought one of these for £14 in the today's deals....
http://www.amazon.co.uk/dp/B00AWM7PKO/ref=...=563170927
Need to get a couple cat 6 cables now....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #309775 1st Feb 2015 7:22pm
Andy B
Looks a good deal Thumbs Up The house I am trying to buy has UTP throughout, so will be looking to buy a similar bit of kit Very Happy SDV8 AB MY 2019
Post #309785 1st Feb 2015 8:03pm
You only need cat5e for 1gig surely so could save some pennies there as cat6 is beyond the 1gig spec and doesn't offer much more for what you pay sometimes Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #309905 2nd Feb 2015 10:50am
Cat 6 cables are cheap these days. It's only when you get to Cat 7 that the prices gets a bit too much Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #309947 2nd Feb 2015 12:44pm
