Home > Technical (L322) > Annoying Radio |
Do you have an aftermarket phone kit installed or anything else that's non standard?
8th Sep 2010 10:22pm |
stefME13 Member Since: 05 Sep 2010 Location: Kent Posts: 11 |
Hi Dan, Thanks for that. It does have an aftermarket Rear Entertainment system DVD/PS2 Which I can't get to work properly. I'm a bit of a numb nuts when it comes to anything electrical so I'll have to get it looked at. Can anyone recommend someone in South East Kent? |
9th Sep 2010 6:44am |
9th Sep 2010 6:45am |
I finde my radio incredibly annoying but if I turn Chris Evans off it gets much better. 2008 MY Supercharged
9th Sep 2010 7:20am |
Chris is OK! But one minute he's shouting and then the next whispering!! lol |
9th Sep 2010 7:26am |
iT LAD Member Since: 08 Jul 2010 Location: Surrey Posts: 1350 |
9th Sep 2010 9:11am |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi Stef, I'm going to go for a more basic answer just on the off chance. If your volume goes up and down, is it when you speed up and slow down and does it also occur on the CD player etc? If it does, it's most likely the AVC (Automatic volume control) is set too high so that small increases in speed cause the volume to go up noticeably (and vice-versa). I have the touch screen but assume pre-touch etc have the AVC somewhere and I set it a bit too high once and as I say went onto a motorway slip road, the volume ramped up too much, so I turned the sensitivity down. Just a thought. Steve
13th Sep 2010 4:49pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Not noticed AVC on my 2003 but maybe I've not looked hard enough.
14th Sep 2010 1:22am |
Update to annoying radio!!! Hi all after being without my ffrr for 5 weeks now, yes that's right 5 weeks. The dealer has finally come up with the fix!!! The car went into Land Rover for a diagnosis and the sat nav unit was found to be faulty, the part was ordered and fitted in under a week but didn't solve the problem with the radio.
12th Nov 2010 1:16pm |
That's called the Rear Seat Entertainment option |
12th Nov 2010 4:03pm |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I had something odd the other day where the volume kept rising on its own - nothing to do with speed, just getting louder. Happened one time and hasn't come back. |
12th Nov 2010 5:36pm |
