Home > Technical (L322) > HEATED STEERING WHEEL L322 VOGUE
Page 1 of 3 123>
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
hi folks
i have a fault with the heating of the steering wheel. it has never actually worked since i have had the car but was wondering what it may be.
when i press and hold the button on the wheel, it has a little light which momentarily comes on red, then goes off.
i assume it should be green? but if anyone has any ideas, i would be pleased to hear
kind regards
bob
Post #311515 8th Feb 2015 3:17pm
sako243
Mine is working and is always red. Never needed to hold it, just a simple push does it. Ed
Post #311516 8th Feb 2015 3:37pm
BOBCUSSEN
HI? when you push it, does the red light stay on?, as if i press mine and let it go, the light comes on then goes out again. if i hold it down, the same happens, ie the light comes on then goes out Exclamation
Post #311518 8th Feb 2015 3:56pm
Yes - push momentarily and it stays on - red all the time - press again & it goes off
Post #311519 8th Feb 2015 4:00pm
Welshdragon
Red light stays on when heated steering wheel is on. If it dont work.......burn it!
Post #311520 8th Feb 2015 4:01pm
sako243
What he said ^^^ Ed
Post #311521 8th Feb 2015 4:01pm
BOBCUSSEN
well it doesent stay on when i push it so i guess it needs a new heater element or wheel?
bummer, but i think i will make do without it !, however if it was completely broken i would have thought the light would not come on at all.
bob
Post #311525 8th Feb 2015 4:28pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Mine stays on, might be a temp. triggered issue. As soon as it gets hot it shuts down
Post #311526 8th Feb 2015 4:29pm
BOBCUSSEN
yes perhaps it has to be below a certain temp to trigger , just like the fuel burner ? but i have tried it in the dead of winter and has always done the same as it does now? so probably u:s
Post #311528 8th Feb 2015 4:33pm
There is an ECU box in the steering wheel behind the Airbag... Probably unserviceable sir Neutral
Post #311532 8th Feb 2015 4:42pm
Discotigger
I have exactly the same problem, press the button and light comes on then goes straight off again. It's the heater element broken, so need to get a replacement wheel.
Will maybe look into a replacement wheel off fleabay, when I've got some pennies spare. Whistle
Post #311533 8th Feb 2015 4:43pm
BOBCUSSEN
ok ; that explains it i expect. i dont think it warrents paying out for another wheel, just to get the heating working.
thanks guys
bob
Post #311536 8th Feb 2015 4:46pm
J90
France 2006 Range Rover Vogue Td6 Java Black
Buy a nice pair of driving gloves. Keep your hands warm and save money Whistle Travelling around in circles again.
Post #311563 8th Feb 2015 6:31pm
BOBCUSSEN
GOOD idea Whistle
Post #311566 8th Feb 2015 6:37pm
Have you thought it might be a faulty switch?
I would try taping the switch in the down position and see if the wheel heats up at all if it was mine.
Leave it for about 10minutes if you try it.
Post #311569 8th Feb 2015 6:42pm
Page 1 of 3 123>
