![]() | Home > Technical (L322) > Couple of 2010 questions |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Hopefully not a case of RTFM, but got a couple of knowledge gaps I can't figure out. Never had a 2010 before so whole electrical system is new to me.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
1.. on the auto lock , as you say they lock when you reach 15mph? but for unlock you have to double pull on the inside lever to unlock or use the central dash unlock button..
Thanks both. Will start with a new cable then! As for CL, clearly just poor design.. My Previous RR's!
JLR obviously don't think that Discovery drivers will ever get robbed!!! |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
1/ All above correct but you can enable the auto unlock in the CCF using a Faultmate or possibly IID tool.
Thanks Andy, I've ordered a cable now so will try it first but the part number would be good.
