Hi to all.Car's (TD6)heating has the following problem.
For having hot air in car i must ONLY follow specific procedure:
1.To set both temp knobs to max temp position ( so i can have only really hot)
2.switch on heating only when car is on very low speed.
When on higher speeds if i reduce temp even by one degree from max either fm driver's or co driver's knob,then air from respective side and also from back seats vents, gratually becomes cold and if i want to make it warm/hot once again i must reset knob to max temp and really reduce speed or stop moving car.
Any idea what can cause such a problem,other than stepper motors which checked by the workshop and found ok
can it be hvac programming as per workshop suggestion?????
many thanks for your assistance.
